On one of the drives, I am getting this at the end of the partition procedure:
Command (m for help): p
Disk /dev/hdc: 255 heads, 63 sectors, 14593 cylinders
Units = cylinders of 16065 * 512 bytes
Device Boot Start End Blocks Id System
/dev/hdc1 1 5 40131 5 Extended
/dev/hdc2 6 10 40162+ 83 Linux
/dev/hdc3 11 13 24097+ 10 OPUS
/dev/hdc4 14 14593 117113850 83 Linux
/dev/hdc5 1 3 24034+ 83 Linux
/dev/hdc6 4 5 16033+ 82 Linux swap
Command (m for help): w
hdb: read_intr: status=0x59
hdb: read_intr: error=0x01
ide0: reset: success
end_request: I/O error, dev 03:40 (hdb), sector 48194
Unable to write /dev/hdc
empeg:/empeg/bin#
The other drive worked fine. Does this smell like a defective drive? Is there a way to be sure and wipe out the drive before starting the procedure so that I can be sure it's clean?
- Thanx
- Jon
284054-Jontxt.txt (243 downloads)
