Wow, two Empegs go on the same day (Bill's also on the 20th).
I believe I'm running 2 beta 13, though my emplode is 2.0.14.0 (not sure that means anything). Also running Hijack 4.17. Had my empeg for 2.5 years now, have had the no hard disk message several times. Recrimped the connector last year and I've been fine since. On Monday, the player was working fine all day, then I get back in the truck, and it won't boot, and nothing's worked since. Opened her up and the main connector needed crimping, but that didn't help, either. One of the pads on the connector at the motherboard almost looks like it never had solder on top of it. But there is no wiggling that I can tell. I rebooted with pressure on the main connector, and nothing different. Any help is appreciated. I'll be gone over the weekend, so I'll let the great minds here stew...
Here's the serial boot ( it just stops mid-line at different points each boot, HT doesn't recognize any keypresses, either). Apparently there is a bad sector on the drive, but I'm not positive what to do now. I can't drop to the shell prompt for some reason.
Okay, there was some funny stuff going on copying and pasting from hyperterminal, so I kept rebooting, trying to get a good log. Basically, over 15 or 20 boots, I was getting a lot of read_intr status= 0x59 and 0x1 errors. Bad sector....3:00 sector 0, I believe. Trying to copy, a lot of the lines were getting mixed around, a lot of "drive1/fids", etc. lines were being inserted in random spots. Then this happens...
Well damn. She just booted for the first time in about 20. So here's that log (weird things missing and inserted in it, too.):
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)s recommendedoting the kerne
/drive1/fid
empeg-pump v0.03 (19980601)ffff, read e91ba9f0
P
NetWinder Floating Point Emulator V0
03:05: rw=0, wa
e000 v1.040 Corp./dr
Copying kernel.../
dev 03:05 blksi
Calling linux kernel...=2 size=1024 count=1
Uncompressing Linux..................................... done, booting the kernesuperayer (hardware revision 9, se
al number 30102917) 16MB DRAM
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v417 (hijack@rtr.ca) (gcc version0/fi
Command line: mem=16mdrive0/fids/1e461s/
2.95.3 20010315 (release)) #2 Sat Jan 15 19:12:21 EST 2005lay loop... 207.67 BogoMIPS
Processor: Intel StrongARM-1100 reive0/
POSIX conformance testing by UNIFIXempeg dsp mixer initialised
Linux NET4.0 for Linux 2.2sp initialised1 -> /drive0
Based upon Swansea University Computer Society NET3.039g audio-in initialised, CS4231A revision a0
empeg remote control/panel butt
IP Protocols: ICMP, UDP, TCPs/1e630/fids/e940 -> /drive0
empeg usb
empeg state support init
Starting kswapd v 1.5
Probing primary interface...ialised
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTTA DISK driveds/1e6c1 -> /drive0/fids/1e6c1
ide0 at 0x000-0x007,0x038 on i
/dri
empeg dsp initialised194.c:v0.12 03/06/96
/drive1/f
SMC9194: SMC91C94(r:
empeg usb initialised, PDIUSBD12 id 1012/
empeg state support initialised 0089/88c1 (save to d0005e80).
/drive1/fids/f8c1 ->
hda:
empeg RDS driver initialised
/drive1
empeg power-pic driver initialised (first boot)1ive1/fids/f
RAM disk driver initialized: 16 RAM disks o
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)EXT2-fs warning: checktime reached, running e2fsck is r
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:6
/drive1/
VFS: Mounted root (ext2 fi
5
Partition check:ve1/fid
hda: hda1 < hda5 hda6 > hda2 hda3 hda417-empeg52-hijack-v417 (hijack@rtr.ca)
VFS: Mounted root (ext2 filesystem).drive1/fid
/drive1/f
empeg-pump v0.03 (19980601):s/1e880 -> /drive0/fids/
Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly.ad e91
Mounting proc
No secondary hard disk
Starting player
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
Empire: Version 0.40 starting...
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
IrDA: Registered device irda0
Edited by MinerTwoFour (24/02/2006 02:26)
