Similiar capture from Hyperterminal w/Rio cable.
> empeg single channel IDE
> Probing primary interface...
So I take it the single should be a dual channel, I had never noticed in previous captures, when it worked, it was a dual.
I'll try your suggestion.
As a side note I did have to replace the display fuse that blew when plugging it in one pin off. You know the fuzzy display problem described here display fuse
The 'single IDE' wouldn't have anything to do w/it would it? I didn't think so I didn't mention it initially.
275731-capture2.txt (341 downloads)
Edited by Snowshoe (04/02/2006 20:45)
