I sent this to support@empeg a couple days ago; haven't had a response yet, so I figure I'd get some of ya'lls opinions.
I did play around with the options a bit, to make sure the cell phone mute wasn't a problem, which it wasn't (it's set to Never mute).
Hey guys,
Last night I finally got around to upgrading to 1.02 developer. I kept
forgetting to bring the player back to the car, and when I did this
afternoon, I noticed that there was no audio being put forth from the
unit. Everything else was ok, the boot, the upgrade, and so on.
I did notice that when trying to change the volume when the empeg was in
the Jeep, it went VERY VERY slow... if I held down the left arrow for like
3 seconds, it would very slowly drop all the way to - infinity (mute).
And the player even locked up after tinkering with it a little while.
I tried powering it up from home, it booted fine.. but again, no output
from the audio outs.
Here is a dump from the boot:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
On DC power, quick boot
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the
kernel
Linux version 2.2.14-rmk5-np17-empeg41 (mac@aphex.internal.empeg.com) (gcc
versi
on 2.95.2 19991024 (release)) #135 Wed Jan 10 17:16:23 GMT 2001
empeg-car player (hardware revision 7, serial number 60000046)
Command line: mem=12m temp=21
Memory: 10992k/12M available (972k code, 20k reserved, 296k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11
1999 )
Starting kswapd v 1.5
Signature is ffffff'
Logo type is 0
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0005f80).
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC
00:02:d7:0c:00:2
e
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
ch
ange_root: old root has d_count=1
Freeing unused kernel memory: 8k initI see this is a developer image!
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To
CompStarting
player
empeg-car 1.02.
3a8d7200 DHCP Our mac is 00:02:d7:0c:00:2e
3a8d7200 DHCP Our address is 255.255.255.255
3a8d7200 DHCP Broadcast address is 255.255.255.255
3a8d7200 DHCP Current IP address is 255.255.255.255
3a8d7200 DHCP Sending DHCP discover
i2c: Failed to receive ACK for data!
i2c_write: write second byte failed, count:38
i2c_write: address select failed
i2c_write: address select failedi2c: Failed to receive ACK for data!
3a8d7201 DHCP Sending DHCP discover
3a8d7203 DHCP Sending DHCP discover
3a8d7207 DHCP Sending DHCP discover
... and so on.
Whenever I change the volume, it spews out those i2c: Failed to receive
ACK for data errors.
I wanted to send you this before I tinkered with it anymore (going back to
1.01, etc, to see if you have any idea what the problem is.
Any ideas guys?
(O|||||O)
(O|||||O)
