Hi All,
I'm getting a similar problem, nothing works apart from the hijack menu. My computer doesn't for some reason have hyperterminal on it either so am using Tera Term. Working with V3A11 developer version.
Check this for a log.. problem is, none of the commands in the faq have any affect at all. Any ideas anyone?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #15 Mon Jul 25 18:52:48 BST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 30102459)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK2018GAS, ATA DISK drive
hda: TOSHIBA MK2018GAS, 19077MB w/0kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:9
b
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
serial_notify_thread.cpp: 116:@@ N11
serial_notify_thread.cpp: 117:@@ F0x8190
serial_notify_thread.cpp: 118:@@ TStreamline
serial_notify_thread.cpp: 119:@@ APendulum
serial_notify_thread.cpp: 120:@@ GDrum & Bass
serial_notify_thread.cpp: 170:@@ S1
serial_notify_thread.cpp: 180:@@ #8190 0:00:02
Much appreciated.
Looks like I was a little premature. This is from the bottom...
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin#
Edited by Raas (26/09/2005 19:39)
