Thanks, guys. I read the FAQ and I had fun at DragonCon (who can not have fun when you get hugged by Tricia Helfer!).
I have taken it apart and I do not really see anything obvious. The cable is glued on. The cable may need to be crimped better, though. I can't tell if any solder joints are broken or not...If there are, I am screwed unless someone can repair it for me...
Here is the result of me connecting it to HyperTerminal:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 7, serial number 90000611)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005780).
empeg RDS driver initialised
RAM disk driver initialized: 16 RAM
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:6
3
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
What does it mean? I don't have the patience right now to figure it out so any help is appreciated...
Squid2k1 --- 18GB of revived Green Mk II Fury - Fast As A Shark
