Rockford Fosgate Symmetry EP2x with either E14 or E28 upgrade card will do great. Remember the (master) volume moves to the remote control if you want to preserve Signal to Noise ratio. I used the Symmetry and noticed line noise, I locked the EMPEG at 0dB and, using the volume on the Rocky after that it was superb.
RF has volume dependant eq, 16 EQ presets, 2 line or balanced inputs, faders. Alll DSP is digital 14 bit.
HTH
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
