Ok, I am then proceeding
Here's the boot info BEFORE the manual fsck
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v429 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue May 10 20:39:19 EDT 2005
Added temporary pagedir entry for flash memory access
Checking for extra DRAM:
c1000000: wrote ffffffff, read e2811004
empeg-car player (hardware revision 9, serial number 40103216) 16MB DRAM
Command line: mem=16m
Memory: 15012k/16M available (984k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x98b7c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005500).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHU2100AT, ATA DISK drive
hda: FUJITSU MHU2100AT, 95396MB w/8192kB Cache, CHS=12161/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:90
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
qMounting second music partition
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Comply.Starting player
Timezone: MET
Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 90 (adjustment 10)
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
q
q
q
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x40693000
Restored terminal settings
Player exited normally: 0
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin#
Sorry for the "q" here and there
I am not at the command prompt and I am sending the commands in a moment.
