When i have hypterminal open after i apply the builder image it says
artition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Freeing unused kernel memory: 4k initDrive(s) appear to be already built. Skippi
ng.
Press return to continue anyway - anything else to start a shell.
But when i press enter nothing happens.
