So, I moved the power lead from the factory HU to the antenna lead on the tuner and when I did that the empeg refused to boot.
I'm guessing you moved the wrong wire, or hooked something up wrong, or crossed a wire somewhere, or something. I'm thinking along the lines of a power or signal feed getting hooked up to a ground, or a power feed hooked up to a signal feed. Something like that.
Then the EMPEG started working and the antenna amp got power but the system made a loud pop when it shut down.
Continued indications of the error above. Also, potential indications of a blown fuse on the empeg main power lead. Or some sort of negative voltage getting applied to something that expects a positivie voltage or vice-versa.
