I upgraded my 36GB 2-drive player to a ~100GB 2-drive player by replacing an 18GB IBM drive with an 80GB Toshiba drive. I did manual formatting and copying and all was well.
Now, I intermittently get a screen message "No hard disk found" or something like that. Power down/up, sometimes four or five times, and all is well again.
I've checked cable connections, jumpers, I've recrimped the cable, checked solder joints.
Any suggestions? Is there a known serial number range that has "dodgy cables"? My S/N is 080000480. Other than the cable, all I can think of is the IBM drive doesn't play nice with the Toshiba drive...
Any suggestions?
Here's part of the console output when it fails:
Vcb: 0x4054d000
ÿIf there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Tue Aug 17 18:05:30 EDT 2004
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 7, serial number 80000480) 12MB DRAM
Command line: mem=12m
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel but
empeg state support initialised 0089/88c1 (save to d0004e80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: TOSHIBA MK8025GAS, ATA DISK drive
hdb: TOSHIBA MK8025GAS, 76319MB w/0kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:e
0
Partition check:
EXT2-fs warning: checktime reached, running e2fsck is recommende
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...rnel panic: VFS: Unable to mount root fs on 03:05
Note that it can't seem to find the IBM drive on hda. When it was failing, I did unplug only the Toshiba drive (2nd drive postion), and it did boot up fine and could find the IBM drive.
thanks for any help/advice.
-gbeck
