Hello,
Emplode imports songs such that position and track number were in order. If you pressed the down button 3 times and played randomly, then unsorted the playlist, it would unsort around the album the song was playing from (if you had your filenames right).
1)With soup playlists is position important in jEmplode? If so, how do you get songs to import such that, basically, position number corresponds to track number instead of what seems to be the default jEmplode way of position number is determined by alphabetical sort of titles.
2)How does autosort on import work? what 'fields' for tag name works? ie: fid, FID, {fid}, etc.? is there a field for filename?
Bottom line: Can you get a shuffled Down Button pressed 3 times to unsort around the album the playing song is from?
Thanks.
