First Letter of Tag and Range soup layers properly accounts for leading articles
Removed automatic selection of properties text field contents (Sorry Tony
![](/ubbthreads/images/graemlins/frown.gif)
Auto-filling soup playlist fields update based on changes to contained tunes (new refreshDependentTags boolean .jempegrc entry that will disable this).
Soup playlists that contain one tune are no longer always removed and readded when dependent tags change, only if it is empty after the change is complete will empty playlists be removed (fixes bug with single entry soup playlists disappearing from the table view after making a tag change)
Note: Currently auto-fill does not compare on the article-removed versions of tags, so if you have a playlist with two tunes, one artist = "The Beetles" and the other artist = "Beetles", the playlist's Artist field will be "Various" even though an articeless-collation-compare would say they those artists are the same.
