#219961 - 15/08/2001 00:15
Re: Win 2k, ME, or Win98?
Yeah, the Receiver is 10Mbps-only. But it seems that you've had it working on the same switch, just with the server on a different machine.
When it fails to work, check the error message displayed on the front. It'll tell you which network adapter (ethernet/PNA) it tried to boot from, and whether it got an IP address or not.
If it's attempting to boot from PNA, then there's a link problem. Check this out first.
If it's not getting an IP address, then there's a problem with the DHCP server -- try running your own. The Receiver will work perfectly with the Win2k DHCP server, or with dhcpd on Linux.
If it's getting an IP address, then it's failing to find either the NFS or HTTP server.
If it's finding the NFS server, the logo on the display changes (it acquires an extra dot, IIRC).
If the second kernel finds the NFS server, then the screen changes to display the Audio Receiver logo, and says "Finding music server" in a box.
If it's still not working, I'd suggest getting a network trace and taking a look at it. If it's not obvious, send the trace to me (rlipscombe@riohome.com), and I'll take a look at it.
Roger - not necessarily speaking for empeg
ajpaterson
07/05/2001 09:08
mardibloke
07/05/2001 18:11
SRVANY - WOL ethernet
sidney
12/07/2001 09:58
Re: SRVANY - WOL ethernet
mardibloke
12/07/2001 12:27
Big John
12/05/2001 13:43
digimark
13/08/2001 21:47
digimark
14/08/2001 16:50
mardibloke
14/08/2001 17:15
digimark
15/08/2001 05:31
mardibloke
15/08/2001 08:35
mardibloke
15/08/2001 13:01
loren
15/08/2001 17:24
digimark
16/08/2001 06:51
mardibloke
14/08/2001 14:12
