This is the boot log for the original confirguration (30GB primary, 80GB secondary):
Probing primary interface...
hdb: IC25N080ATMR04-0, ATA DISK drive
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:5
a
Partition check:
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
This is the log with only the 80GB drive
hda: IC25N080ATMR04-0, ATA DISK drive
hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
a
Partition check:
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5chang
e_root: old root has d_count=1
Mounting proc
No secondary hard disk
Starting player
Timezone: /usr/share/zoneinfo/CST6CDT
! tags.cpp : 61:Failed to open tags (0xc0041002).
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin#
...and the log from the reversed case (80GB primary, 30GB secondary)
a
Press Ctrl-A to enter pump...ԕсɽс٥)5Kernel panic: VFS
: Unable to mount root fs on 03:05
32MB, serial: 10101626
