Thanks Donato-
No problem.
That sound like an ideal solution.. not to mention that it only 'updates' my older style motherboard as well.
I did some digging in the meantime, and I did discover that there is a place in v1.01 software to assign an IP, a mask, and gateway. I did not realize it was there, I only used the IP section from the very first screen where it asks you your connection type.
I still tried to set up IP to work and got the same result. Yeah well, I guess I was just not meant to use the program with ethernet. I didn't want to use it anyway.. sour grapes!
I guess CompUSA will be getting a couple more bucks from me for a USB port tomorrow.
You know, depending on what type of computer you currently have, you could be better off just getting a new motherboard. Unless money is a big issue, and even then I still think it'd be a better investment
________
Donato
MkII/Blue/40GB/080000565
ricin
MkII/080000565
MkIIa/010101253
ricin.io
