In reply to:
I've got a couple of sources for the LEDs but am not sure they'll work with Stu's button kits. I've pinged Stu for an assist but does anyone else know if these will work?
Hmm, never got anything from you. The UV T1 LEDs should work fine. Their forward voltage is within 1/10 that of the white ones we use. I don't see a link for UV surface mount LEDs in your links. I can probably get them if you need them for the knob board. And as far as that goes, here are the dimension used in the surface mount pads we have on our knob boards:
Stu
