OK, I tried removing the files as the instructions said, sans the drive1 as I only have 1 drive. Still the same thing. As a side note I also have no playlists now on the player after it boots (they used to be there). I believe I caused this when jEmplode said it was not syncronized on exit and I told it to sync. I thought maybe it would help.
Can anyone tell me where I can find instructions on reformatting the disk and starting from scratch. I think that may solve my problem and I only have about 8.5 gigs of mp3s to put back on there.
q
Restored terminal settings
No secondary hard disk
Player exited normally: 0
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin# rw
empeg:/empeg/bin# rwm
empeg:/empeg/bin# rm /drive0/var/database
rm: cannot remove `/drive0/var/database': No such file or directory
empeg:/empeg/bin# rm /drive0/var/database3
rm: cannot remove `/drive0/var/database3': No such file or directory
empeg:/empeg/bin# rm /drive/var/tags
rm: cannot remove `/drive/var/tags': No such file or directory
empeg:/empeg/bin# rm /drive0/var/tags
rm: cannot remove `/drive0/var/tags': No such file or directory
empeg:/empeg/bin# rm /drive0/var/playlists
rm: cannot remove `/drive0/var/playlists': No such file or directory
empeg:/empeg/bin# rom
empeg:/empeg/bin# exit
logout
Shell exit
Starting player
player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.
! tags.cpp : 61:Failed to open tags (0xc0041002).
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 30102445)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:8
d
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
hda: read_intr: status=0x59 { DriveReady SeekComplete DataRequest Error }
hda: read_intr: error=0x40 { UncorrectableError }, LBAsect=137941, sector=4882
end_request: I/O error, dev 03:03 (hda), sector 4882
hda: read_intr: error=0x40 { UncorrectableError }, LBAsect=137941, sector=4884
end_request: I/O error, dev 03:03 (hda), sector 4884
Prolux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
Adding Swap: 16596k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
! playerdb.cpp : 182:Failed to build dynamic database (status=0xc004401a).
Restart code received
Starting player
Vcb: 0x4086d000
Daniel
[blue] 10G MkIIa [/blue]
Quantum Mechanics: The Dreams Stuff are made of.
