Peter, I re-applied 2.0final by double clicking on the .upgrade file and following the wizard through until completion, and I am still having the problem. This is my boot log:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 30102782)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004c00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-210, ATA DISK drive
hda: IC25N040ATCS04-0, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
hdb: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:d
e
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Vcb: 0x4086d000
serial_notify_thread.cpp: 180:@@ #0 0:00:00
serial_notify_thread.cpp: 170:@@ S0
After the player boots successfully, I then go into Emplode 2.0, I modify a single track to change the database (this time I deleted a duplicate track I had marked), and then press the Sync button. The serial log shows:
Adding Swap: 16028k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
hdc4 is mounted.
! playerdb.cpp : 182:Failed to build dynamic database (status=0xc004401a).
Restored terminal settings
Restart code received
Starting player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Is there anything else you need to see to debug this problem?
Mark Cushman
