Hi all,
I think I've just experienced my 3rd hard disk failure in 18 months of empeg use. It's different to the previous hard drive failures I've had and so I am posting just to get confirmation and the opinion of you guys as to my options.
The symptoms started a few weeks ago with occasional boot problems: hard disk not found, hanging during Tux's logo, hanging during playlist initialisation. Around this time the player started hanging during playback- although music would continue playing the buttons ceased to have any effect. Soemtimes the player would completely forget to store state information so when I rebooted it would be at some earlier point in the playlist than when I had shut down.
Soooo, the other day I booted her up and she got as far as "Loading playlists", "Loading database" and just cycles between the two messages over and over. In the console I can't seem to get into any kind of bash prompt but I have obtained the following boot sequence dump - showing player.cpp experiencing a memory violation, preceded by a failure to mount a particular partition...
Any suggestions? The cause? Help! The silent journeys to work are making me crazy!
-nic
----- console dump:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v336 (root@ibbm) (gcc vers
.3 20010315 (release)) #2 Wed May 28 20:13:55 EDT 2003
empeg-car player (hardware revision 9, serial number 30103054)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Page cache hash table entries: 4096 (order
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb88
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004500).
empeg RDS driver initialised
empeg power-pic driver initialised (first b
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHR2030AT, ATA DISK drive
hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)1734e4 (bad address=0x421
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:e : [<02035370>] lr : [<021734e4>]
sp :
ef
Partition check:87d fp : bffffa
r10: 00000000 r9 : 021734d8 r8
r7 : 00000373 r6 : 000007fa
r3 : 4218b7d0 r2 : 50005546 r
empeg-pump v0.03 (19980601)Qs on FIQs on Mode USER_3
Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly.ntrol: C0F4D17D Table: C0F4D17D DAC: 00000015
change_root: old root has d_count=1red at [<0203525c>] from [<02035120
r8 = 02112668 r7 = 00000000 r6 = 02173490 r5 =
Tried to mount /dev/hdc4 but got error 6n entered at [<02036c28>] from [<0202fd7
r10 = 00000000 r9 = 02112374 r8 = 0214D808 r7 =
r6 = BFFFFD84
Function ente
No secondary hard diskm [<0202f758>]
Press 'q' now to go into development mode. You Have Zero Seconds To Comply...= 0214D808 r7 = BFFFFEE8
Starting player
kftpd: listening on port 21
F
r10
player(9): memory violation at pc=0x02035370, lr=0x021734e4 (bad address=0x4218b
r6 = 020000C0 r5 = 00000001 r4 = BFFFFF64
7d4, code 2)
pc : [<02035370>] lr : [<021734e4>][<02031730>] from [<020c8ea4>]
sp : bffffa34 ip : 0000087d fp : bffffa84r5 = BFFFFF64 r4 = 00000001
r10: 00000000 r9 : 021734d8 r8 : bffffab48>] from [<02000104>]
r7 : 00000373 r6 : 000007fa r5 : 02173490 r4 : bffffa40 r7 = 00000000 r6 = 00000000
r3 : 4218b7d0 r2 : 50005546 r1 : 0218fe40000 r4 = 00000
Abnormal player termination
r10 = 00000000 r9 = 00000000 r8 = BFFFFAB4 r7 = 00000000
Starting player
Hijack: intercepting config.
r6 = BFFFFA88 r5 = 02173490 r4 = 0218DAA8cpp : 385:empeg-car 2.00 2003/04/01.
Function entered at [<02035008>] from [<02036e0c>]
player(384): memory violation at pc=0x02035370, l
r8 = 02112668 r7 = 00000000 r6 = 02173490 r5 = 000012CC
8b7d4,
r4 = 000008E5
pc : [<
Function entered at [<02036c28>] from [<0202fd70>]
r10 = 00000000 r9 = 02112374 r8 = 0214D808 r7 = BFFFFD8800000000 r9 : 021734d8 r8 : bffffab4
Function entered at [<02031464>] from [<02031794>]
r6 = BFFFFA88 r5 =
r10 = 02031730 r9 = 00000000 r8 = 02112060 r7 = 00000000
Function entered at [<02031730>] from [<020c8ea4>]
r4 = 000008E5
Function entered at [<0202fa
Restored terminal settings
Remounting first music partition read-only0000001 r8 = 0214D808 r7 = BFFFFEE8
r6 = 00000086 r5 = BFFFFDF4
Abnormal player terminationd at [<0202f718>] from [<02
Player received signal 11
Starting player000086 r5 = FF
Hijack: intercepting config.ini
r
player(12): memory violation at pc=0x02035370, lr=0x02
Function entered at [<020c8d
r10 = 00000000 r8 = 00000000 r7 = 0000000
r3 : 4218b7d0 r2 : 50005546 r1 : 0218fe48 r0 : 1000110e
r5 = 00000000 r4 = 00000000
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F4D17D Table: C0F4D17D DAC: 00000015ng second music partition read-only
Function entered at [<0203525c>] from [<02035120>]k
Starting player
Hijack: in
r5 = BFFFFF64 r4 = 00000001 r6 = 02173490 r5 = 000012C
Function entered at [<020c8dc8>] from [<02000104>]
r4 = 000008E5
Function en
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r6 = BFFFFD84 r5 = B
Function entered a
player(15): memory violation at pc=0x02035370, lr=0x021734e4 (bad address=0x4218
b7d4, code 2)
pc : [<02035370>] lr : [<021734e4>] r8 = 02112060 r7 = 00000000
r3 : 4218b7d0 r2 : 50005546 r1 : 0218fe48 r0 : 1000110e]
Player received sig
r8 = 02112668 r7 = 00000000 r6 = 02173490 r5 = 000012CCr 2.00 2003/04/01.
Function entered at [<0202fa0c>] from [<0202f758>]
r10 = BFFFFEE4 r9 = 00000001 r8 = 0214D808 r7 = BFFFFEE8
r6 = 00000086 r5 = BFFFFDF4 r4 = BFFFFDF4
Function entered at [<0202f718>] from [<02031668>]
r6 = 00000086 r5 = FFFFFFFF r4 = BFFFFDF4
Starting player
<<<<this just recurs endlessly, cycling the same error over and over>>>>>
