Okay, skins for this are fun. That was a great idea. I've thrown together a few sloppy skins, and even sloppy ones are cool.
I really want to release the skinnable version, but I'm having a bug with it. The trick with testing for a button hit via a bitmap isn't working from VB when the system's color depth is anything less than 24 bit color. As soon as I set the system down to 16 bit color or lower, the "point" command that lets me sample a pixel from a bitmap stops returning valid values. I'll mess with it some more and see if I can fix it. In the meantime, would folks be interested in a skinnable version that required you to run it in 24-bit color?
