Here's an image for the non-window folks. I should point out it doesn't as much detect "combing" as it does songs off the same album close together. In the test run I just did, only 86 pairs (in 3000) were close together, and many of these might have been couples rather than full-blow "combing". I should add that since each pair is only noted once, the number of actual songs involved is higher than 86 (172 if all songs were couples and not triples, etc.) In addition, in the first thirty songs (where I determined you'd probably most notice the effect) only two songs from the same album were close together. Clearly this program is limited in what it tells us, but my first feeling is that we are seeing more "combing" on the Empeg than we should.
-Jeff
