Ok, this is what I have got from hyper terminal, what does it mean?
empeg-car v0.04 19990121 (altman@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux........................ done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #9 Tue Apr 1 18:47:56 BST 2003
Processor: Intel StrongARM-1100 revision 9
empeg-car player (hardware revision 4, serial number 00017)
Command line: mem=8m
Memory: 7324k/8M available (580k code, 20k reserved, 264k data, 4k init)
Dentry hash table entries: 1024 (order 1, 8k)
Buffer cache hash table entries: 8192 (order 3, 32k)
Page cache hash table entries: 2048 (order 1, 8k)
Linux NET4.0 for Linux 2.2
Starting kswapd v 1.5
Signature is ffffffff '˙˙˙˙'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button support initialised (Using FIQs).
empeg usb initialised, USBN9602 revision 1
empeg state support initialised 0089/8893 (save to d0005180).
empeg RDS driver initialised
empeg power state driver initialised
Linux video capture interface: v1.00
empeg FM radio driver (Philips).
empeg dual channel IDE
Probing primary interface...
No drives found, retrying...
hda: IC25N080ATMR04-0, ATA DISK drive
Registering drives...
ide0 at 0x040-0x047,0x078 on irq 7
hda: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplůStarti
ng player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1425 Mar 26 2003
Vcb: 0x4028d000
Laura
MKI #017/90
whatever
