#158321 - 29/09/2004 07:34
Re: AC Shensor Shwitch
[Re: snoopstah]
Loc: Wellingborough, UK
For anyone else who is interested, RS Electronics in the UK sell it - stock number 286-8779.
I can verify that this part number is compatible with the Empeg board layout. The board holes need to be thoroughly cleaned of solder using flux and solder braid prior to fitting the component (which is currently supplied to RS by SWC).
The leaf switch is much more springy than the original part, so the tactile feel of inserting and removing the power plug is quite different after the repair.
I did the work while I was installing my Eutronix illumination kit. Unfortunately, it didn't fix the symptoms and after some diagnostics work, it looks like I am in the market for an "A6" diode
