I suspect that by the time you've adjusted the position of the switch so that it is optimal and does what you want it to do, you will have popped your speakers more times than you will if you didn't bother.
I'd second the idea of a hidden dash switch that you physically press. What you need is a push-to-break switch. (as opposed to the push-to-make that you'd want in the sled).
