Not sounding good, is it?
Ok, tried connecting via hyperterminal with the hard drive disconnected, and got this:
ÿIf there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v294 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Sat Sep 21 11:0
empeg-car player (hardware revision 9, serial number 40103373)
Command line: mem=16m
Memory: 15072k/16M available (928k code, 20k reserved, 360k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
Probing primary interface... (it waited here for several seconds)
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0d:2
d
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
I then tried plugging the hard drive back in again and turned it on, and bingo, hard drive noise! It stuck at the "Hijack v2.94 by Mark Lord" initial screen. Turned it off, then on again, and once more, hard drive noise, this time it made it to where it did before (the logo screen after animated logo). It flashes for the very briefest of time the "hard drive not found, contact support" screen (something left in memory?). Hyperterminal at this point produced the following:
e000 v1.04
Copying kernel...
rsion 2.95.3 20010315 (release)) #2 Sat Sep 21 11:00:35 EDT 2002
empeg dsp initialiseduest
USB: Non-standard request
empeg usb initialised, PDIUSBD12 id 1012d request
USB:
empeg state support initialised 0089/88c1 (save to d0004a80).d request
empeg RDS driver initialised Non-standard request
empeg single channel IDEtandard request
Probing primary interface...ndard request
hda: ÆUÊIÔSÕ ÍHÍ2±0°AÔ                      , ATA DISK drive
USB: Non
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0d:2st
U
d:
Partition check:uest
hda: read_intr: error=0x10
hda: read_intr: status=0x59
ide0: reset: success
end_request: I/O error, dev 03:01 (hda), sector 0
> hda2 hda3 hda4
Press Ctrl-A to enter pump...X]]Y[\]fs: unable to read superblock
which is strangely different to what it was doing before. It consistently gets to this point now. The only mild comfort I get from all this is that at least the hard drive now spins up and does a small read or write when I turn it on.
Ben
