LED Hack
Button Materials
Buttons
4 button leds: Lens Style/Size Round/3mm, Lead Style Radial, Millicandela Rating 1100, Voltage Rating 3.6V, Digikey Part 67-1606
1 SMD resistor pack: 1k Ohm, 4 resistors, Digikey part Y4102CT or Farnell 196-770 ARV241-1k-5:RESISTOR ARRAY, 1kOhm (size 1206)
Knob Materials
Knob Board: (from Brian) or your own design
1 SMD Transistor: Digikey part MMBT390DICT-ND
2 to 4 100 Ohm SMD resistors: Digikey part 311-100CCT-ND
1 10k Ohm SMD resistor
3 or 4 knob LED’s: LED WHITE 2.8X3.2MM 150 MCD SMD, Millicandela Rating 150, Voltage Rating 3.6V Digikey Part 67-1608
Sled Plugs
1 Male Housing: Digikey Part H10109-ND - QR/P6-24P-C(01)
1 Male Power Terminal: Digikey Part H10085-ND - QR/P1-PC1A-111
22 Male Signal Terminals: Digikey Part H10087-ND - QR/P1-PC2A-111
Female Housing: (Back of Empeg) DigiKey part H10110-ND
Internal Connectors
10-pin header (male): Used for internal connections to docking connector, Molex Part 89400-1020
10-pin housing (female): Used for internal connections to docking connector, Molex Part 87369-1000
Female contacts for above housing: Molex Part 50212-8100
Mk1
Button Cap: Plain circular button cap for mk1 Farnell part 917-461
Docking Connectors: Farnell parts RP16 and RS16
Hard Drive
2mm HD jumpers: Farnell - 510920 (blue), 510932 (black) and 510944 (red), Jameco – 119263, Digikey - A26244
Fuse Replacement
SMD Fuse: FUSE 1.00A 63V 1206 SMD Digikey part WK4661CT-ND
Dimmmer Fix
SMD Capacitor: .01uf (10nF) surface-mount capacitor, Farnell Part 499-225 (size 0805, order multiple=10)
Tuner
Tuner Connector (M/F pair with pins): Molex WMF-3904PRT
Individual Parts
Recepticle (sled/dock end?): 39-01-2080 (digikey WM3703-ND)
Plug (tuner end?): 39-01-2081 (digikey WM3603-ND)
8pc. Male contacts (pins for tuner): 39-00-0041 (digikey WM2500-ND)
8pc. Female contacts (pins for sled/dock): 39-00-0039 (digikey WM2501-ND)
Edited by lopan (27/03/2003 14:52)
Brett
60Gb MK2a with Led's
