e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 30102349)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:2
d
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta13 2002/07/24.
Prolux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
serial_notify_thread.cpp: 116:@@ N12
serial_notify_thread.cpp: 117:@@ F0x690
serial_notify_thread.cpp: 118:@@ TBelieve
serial_notify_thread.cpp: 119:@@ ACher
serial_notify_thread.cpp: 120:@@ G
serial_notify_thread.cpp: 180:@@ #0 0:08:26
serial_notify_thread.cpp: 170:@@ S0
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 8096
718, error=0xc0044000
s
No responce
OK, This player has been working fine for about 6 months. Some of my MP3s did get am error when being played by the Rio. Becuase of these errors I dumped everything, used MP3Trim to scan and fix all problems with the files. After testing a few none "errored" files on the Rio I found that this fixed the problems. I only reloaded a very small portion of the drive and then let that part play all the way though its list. What I am trying to say is I have spent a lot of time to make sure the files are good and that the Rio likes then too. As of a few weeks ago I know for 100% that the files were perfect. If they are bad now what can I do to fix then and mainly for did it happen.
Edited by Turboegt (31/01/2003 12:05)
